For my water cooling loop I am going to build soon, I have a couple of questions to ask before I buy the parts.
-Partlist- http://au.pcpartpicker.com/p/hJ73jX
-Watercooling Loop Partlist- https://docs.google.com/document/d/1bo5H1Hq6k16Qh8nOpFsr2S7xnMsIDuKukQpoz9lLHWc/edit?usp=sharing
Q1) Do I have to include any fittings to secure the soft tubing to the pumps? eg normal 1/2 3/4 tubing onto this pump
Q2) For the rigid tubing part of the build, would these fittings fit onto the rigid tubes and screw onto normal ports?
Q3) I will be changing from rigid tubing to soft tubing. How would I do this? Would I just use a 90º fitting and then attach the rigid tubing to the 90º with this hard tube fitting, and then on the other end use a normal compression fitting for the soft tubing. Is there a better way to do this?
Thanks for any help!
https://linustechtips.com/topic/283743-final-loop-questions/
Answers:
Q1. Nope. Hose clamps of some kind. Zip ties,or something similar to these.
Q2. Yes you could use those.
Q3. I would suggest you do this change at a component like a rad, res or pump, where its solid mounted and won't risk pulling the solid tubing out of its fitting. the use of a rotary 90, an extension and another 90 of a top mounted rad, can allow you to run the tubing behind the mother board tray down to a hidden res for example.
Highly dont recomend doing a change mid run.
Hope this helps!!
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/283743-final-loop-questions/#findComment-3852188
Answers:
Hope this helps!!
I'll be basing this on JayzTwoCents Skunkworks, so I am not exactley sure what to do - haven't really planned it out right now.
Here a couple vids on the computer I am basing it on - pretty much a black/white version of this - if you have any more suggestions they are appriciated! :D
https://linustechtips.com/topic/283743-final-loop-questions/#findComment-3885042
