I just got my G1 Gaming 970 a few weeks ago, and I figured... New gpu might as well clean all the dust out... Well I popped of the side panel and took out my Power supply and when I hit it with the can of air... It got the majority off... But there is still a small layer of dust that won't budge with the air... What can I do? I was thinking of completely dismantling my pc and wiping it all down with isopropyl
Intel i5-3570K @ 4.1GHz  • XSPC Raystorm • FrozenQ 250mm Liquid Fusion • 8GB DDR3 1600 (PC3 12800) • Gigabyte GA-Z77X-UD3H
Gigabyte GTX 970 G1 Gaming 4GB • Seagate Barracuda 1TB + Intel 730 Series 240GB • ASTRO A40 Audio Solution • D-Link N-150
https://linustechtips.com/topic/283552-dust-cleaning-help/
That works. I just use a napkin.
https://linustechtips.com/topic/283552-dust-cleaning-help/#findComment-3848938
Yeah, isopropyl is the best thing you can use on a PC, just don't wipe with anything that'll leave lint. Personally, I use paper towel.
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
https://linustechtips.com/topic/283552-dust-cleaning-help/#findComment-3849273
I used Isopropyl for the dust and it worked great... I just noticed that a run of tubing in my water cooling loop is really tight and is almost kinked... Will it affect anything as long as it isn't kinked?
https://linustechtips.com/topic/283552-dust-cleaning-help/#findComment-3849707
It should be fine as long as it doesn't kink.
https://linustechtips.com/topic/283552-dust-cleaning-help/#findComment-3849771
okay thanks
https://linustechtips.com/topic/283552-dust-cleaning-help/#findComment-3849799
they made a video on it
i know its a joke ,LOL
https://linustechtips.com/topic/283552-dust-cleaning-help/#findComment-3851665
