Thats good then, can you get into the BIOS and check the temps? does it all look ok?
Remove anything in the system that doesnt need to be in it for testing, pci cards like sound cards, use onboard gfx take the gfx card out, unplug all hard drives except your boot drive etc, see if it then boots?
“I'm telling you, people. Everyday we wake up is another blessing. Follow your dreams and don't let anyone stop you. Never say never.” ― Justin Bieber
https://linustechtips.com/topic/283469-boot-problem/#findComment-3847913
please list system specs.
the shut down and start up occur in the boot...... you never see the desktop?
you can't keep tapping the delete key on start up to get into the BIOS? and then set up boot sequence/set time, etc. ??
did you try booting without a graphics card installed? hook monitor to motherboard.....
https://linustechtips.com/topic/283469-boot-problem/#findComment-3850621
Did you install the Motherboards Stand offs? The MB is most likely cutting itself off.
The stand offs are screwed into the Case and then the MB site on it and you screw the screws into the stand offs
I have a problem whit my boot on my PC that I built a month ago. When I turn it on its stays ON and after cca.3-5 sec it turns its self OFF and then back ON. Is this normal I am new to this? Thanks for any help.
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/283469-boot-problem/#findComment-3850655
