Netflix, help.
By
Stav Kats
in General Discussion
Solved by Joshua,
I am currently using that add-on, because netflix is not even available to Greece. That's how I am able to sign up.
Then, unfortunatelty, you cannot get the programmes that you would like. There are some illegitemate websites I could suggest, but I shan't as it is against the rules of the forum.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
