you product code is tied to the old motherboard. if the MB had the same chip set it may have worked without a problem. try calling microsoft help center and tell them you had a lightning strike and your board was destroyed ... ( slots ruined ) and you needed to replace it. )
I see MS being inundated with 50 million call all the same right now............
https://linustechtips.com/topic/283150-help-please/#findComment-3843634
