ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/282747-beeping-sound/#findComment-3838562
What kind of beeping sound? What's the tone and how many times is it repeated?
https://linustechtips.com/topic/282747-beeping-sound/#findComment-3838859
 i got this from the dell website hope this helps
Repetitive Beep Codes 1
Possible motherboard failure - BIOS ROM checksum failure
2
No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly
3
Possible motherboard failure - Chipset error
4
RAM read/write failure.
5
Real Time Clock (RTC) power fail
6
Real Time Clock failure
7
Video card or chip failure.
8
Processor failure
https://linustechtips.com/topic/282747-beeping-sound/#findComment-3839061
