Main Component
Case: Corsair Obsidian Series 900D
Mother Board: ASUS MAXIMUS VI Formula LGA 1150 Intel Z87
CPU: Intel Core i7-4770K Haswell 3.5GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics
Memory: Corsair Vengeance LP 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Video Card: 2x EVGA GeForce GTX 780 3GB 384-bit GDDR5 PCI Express 3.0 SLI Support Hydro Copper
PSU: Corsair 860 Watt 80 PLUS® Platinum Certified Fully-Modular PSU
SSD: Intel 520 Series Cherryville 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD)
HDD: Western Digital WD Black 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive - OEM
Water Cooling
Rad: 2x XSPC RX480 Quad 120mm Radiator
Pump: Swiftech MCP655™ 12v Water Pump w/ Speed Control and 3/8" Conversion Kit (317 GPH)
Pump Mod: Bitspower D5 / MCP655 Extreme Pump Mod Top V2 - Acetal
Reservoir: Bitspower Water Tank Z-Multi 250 Inline Reservoir
CPU BLOCK: undecided
Fans: 10x Air Series SP120 PWM Quiet Edition High Static Pressure Fan
Compression Fittings: undecided
Coolant: undecided
Tubing: undecided
I hope someone can help me finalize my build, i still missing few components such as monitor, keyboard, mouse and other water cooling parts. And is everything compatible? like does my PSU enough for all this? thx
https://linustechtips.com/topic/28195-help-me-finalize-my-build/
yeah, sounds like a great build. what three monitors do you have that needs HP
of SLI GTX780? it looks like the other 30-40 prior to yours. not dumping on ya,
but its the same rig at least 10 members are already attempting to build almost
verbatim.
have you built a water-cooled rig, if not, you might wanna dive into the h2o section
and read the FAQ and water-cooling 101 threads to understand what you need
and what is window dressing...
but good luck with the build, needs a build log, for sure..
airdeano
https://linustechtips.com/topic/28195-help-me-finalize-my-build/#findComment-358883
