edit: Going to be used as a 2k/4k gaming pc.
Been working on a build for quite some time and I've gotten a lot of good advice from here.
My budget is around 14,000 NOK and my components as of now are:
Corsair CX 850M
i7 4790k
Kingston HyperX 8GB DDR3 1600mhz
ASUS Z97-A S-1150
2x Gigabyte G1 970
Fractal R5
Crucial MX100 256GB + Old 1TB WD I'll add in
This is a little over my budget, and I have a couple of things I'm unsure of.
Will the R5 be big enough for 2x G1 970, and if I add in a Hyper 212 cooler for the cpu, will it be enough for mild overclocking or should I be looking at some slightly more expensive options such as the CM H100i?
I'll be buying in a couple of weeks so any advice is welcome
Desktop: Intel i7 4790k, Hyper 212 EVO, SLI Gigabyte 970 G1 Gaming, 8GB HyperX Fury 1600mhz, Corsair CX850M, Fractal Design R5, Crucial MX100
Laptop: Samsung NP900X4C
Peripherals: HyperX Cloud Gaming, NAD Viso HP50, B&W P5, Logitech G710+, G400s, Z623, Galaxy Note 4 (Fiio E18 DAC), Google Nexus 7 (2013)
https://linustechtips.com/topic/281338-advice-on-build/
Is this for gaming?
If so I'd drop from the i7-4790k to an i5-4690k and then you can get a better CPU cooler, like the Corsair H105. The CM Hyper212 works well, but nothing can beat watercooling.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/281338-advice-on-build/#findComment-3819758
Is this for gaming?
The site I'm buying from has a packaged offer, the i5+motherboard separately vs the i7 w/ motherboard in the package would be the same price.
and yeah it's for gaming :)
https://linustechtips.com/topic/281338-advice-on-build/#findComment-3819794
