Installing Water Block
Go to solution Solved by d33g33,
If you can follow instructions, difficulty level 1.
Was wondering if this is hard, I've seen videos of it. Just curious like difficulty scale on 1-10? Heard there are different sized pads with different thicknesses, are the directions from EK pretty clear? Going to be doing the EVGA setup program and getting a GTX 980, and an EK waterblock for it. Just want to make sure I'm prepared I guess for any surprises.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/280347-installing-water-block/
Hmm alright less than I thought I guess, just not trying to fry a GTX 980. Well if I can build a computer from scratch I should be able to do this xD
https://linustechtips.com/topic/280347-installing-water-block/#findComment-3806677
