So my router all of a sudden just started not liking port forwarding. Its an Actiontec V1000H from telus. I have the port 27015 forwarded and nothing changed as far as i know, but one day my port was closed somehow. Does anyone know how to fix? Here is a screenshot of the ports forwarded http://puu.sh/dOH3b/ff715e21b7.png
https://linustechtips.com/topic/279984-port-forwarding-issue/
Does your router have the DHCP service running? Perhaps your desktops IP lease ran out and it got given another IP. Meaning the port rule doesnt match the IP anymore = Blocked port.
How would I find out about DHCP. Also i have a static ip for my desktop so i dont that is it.
https://linustechtips.com/topic/279984-port-forwarding-issue/#findComment-3801646
I googled "extra post farm". Idk what that means. I'm sorry if I broke a rule or something (with a bad joke). I'm new to your forum but have been a LONG time subscriber to your YouTube channel. I was honestly trying to help ( with my second comment ).
https://linustechtips.com/topic/279984-port-forwarding-issue/#findComment-3801715
nah you didnt nvm lol
https://linustechtips.com/topic/279984-port-forwarding-issue/#findComment-3801938
Are you sure your computer was listening on port 27015 when you tested if it was open?
Even if you have port forwards in place the ports will show as closed using tools like NMAP or a 3rd party website like www.yougetsignal.com  if the PC is not actually listening on that port.
https://linustechtips.com/topic/279984-port-forwarding-issue/#findComment-3821857
Even if my friends try to connnect to my server it still wont work. So I dont think that is the problem
https://linustechtips.com/topic/279984-port-forwarding-issue/#findComment-3822037
You would want to use static addressing when port forwarding. Either by setting DHCP-leases or assign one yourself outside the default range. That way you know that the route to your server never changes.
If you also have dynamically assigned WAN-address you would want to use a dynamics DNS to work around that issue.
Tux is a lie.
https://linustechtips.com/topic/279984-port-forwarding-issue/#findComment-3838189
Yeah I have a DHCP reservation for my computer.
https://linustechtips.com/topic/279984-port-forwarding-issue/#findComment-3839879
