Yesterday I wasn't thinking, and turned my pc off by holding down the power button. I was trying to get to the bios fast because it was getting late, and now I regret trying to speed things up. When I turned it back on it said there was a drive error, and that I needed to restart it to fix the problem. When I did it started to load a diagnosing pc menu and started a repair. Then the repair failed and sent me to a menu with other repair options to fix it. Most of the other repair options I can't even do because I don't have a administrator account. I realized that I had probably corrupted my drive, and not just some small file but windows itself. I can even get into windows anymore because it just goes to this failed repair menu every time. I know I will probably have to fresh install windows, but it is not a problem if I lose my files because my pc was just built recently. My specs are mobo: msi h81m e33/ cpu: Pentium g3258/ gpu: amd r9 270x/ psu: evga 500 watt bronze rated/ hdd: wd caviar blue 1tb/ ram: team dark series 8gb. Anyone's help would be very appreciated.
CPU: Intel Pentium G3258/MOBO: MSI H81M-E33/GPU: Sapphire Dual-X R9 270x/RAM: Team Dark Series 8GB DDR3-1600mhz/HDD: WD Caviar Blue 1TB/Case: Corsair Spec-01/PSU: EVGA 500B 80-plus bronze 500 Watts/OS: Windows 8.1 64-bit
https://linustechtips.com/topic/279857-hard-drive-corruption/
You probably corrupted a file. Only option is to reinstall Windows, unless you have a backup to restore from(unlikely).
https://linustechtips.com/topic/279857-hard-drive-corruption/#findComment-3799594
Yep, it's rare but does happen if it's updating or writing a file, reinstall time
Cartman - AMD Phenom II x6 1055T 3.1Ghz - 10GB Ram (Mwahahah) - 256GB Crucial MX100 Boot - 2TB WD Red - Gainward GTX 770 - Zalman Insanely Loud CNPS14X - Corsair 230T Orange
Stan - Intel Pentium G3320 - 8GB Ram - 128GB Intel 520 - Raid 1 6TB WD Reds - Bit Fenix Prodigy
Kenny - HP 14 Ultrabook (No name apperently) i3 4130 - 128GB Intel 520
https://linustechtips.com/topic/279857-hard-drive-corruption/#findComment-3799759
How exactly do I reinstall when I can't even boot into windows? Do I just stick in the installation disk and set that for the boot order? I mean I'm kinda clueless. Thanks for all the help!
https://linustechtips.com/topic/279857-hard-drive-corruption/#findComment-3813596
How do I reinstall? The only reason I made another post is because I forgot to quote you guys. srry
https://linustechtips.com/topic/279857-hard-drive-corruption/#findComment-3813624
Do you have a Windows disc?
https://linustechtips.com/topic/279857-hard-drive-corruption/#findComment-3814245
Yes, and I read the tutorial on eight forums to reinstall. I hope it works!
https://linustechtips.com/topic/279857-hard-drive-corruption/#findComment-3814311
