I just installed a new GPU (Asus r9 290) and power supply (Corsair CX750) into my computer. Unfortunately i have a problem. My computer is randomly restarting without warning and no BSOD. It happens when playing games or when surfing the internet. I went into event viewer and it says Kernel-Power 41 (63) which im guessing means not enough power. but I have a corsair CX 750 watt to power my asus r9 290. Is it not enough power to support my system?????? does it matter what 8 pin and 6 pin i use to plug into my GPU? Or is it something else.
Specs:
Gigabyte Ga-78lmt-s2p Motherboard
Phenom 2 x6 1045T stock cooler
2 x 4gb Corsair vengeance RAM
Asus r9 290 4gb directCU II
Corsiar cx750
old laptop hard drive
OCZ 128gb SSD
https://linustechtips.com/topic/279415-help-not-enough-power/
A 750W is definitely enough for you setup.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/279415-help-not-enough-power/#findComment-3792746
"old laptop hard drive" that means its 2.5 and 5200 RPM maybe thats the issue?
probably not but you never know
https://linustechtips.com/topic/279415-help-not-enough-power/#findComment-3792754
