CPU cooler does not fit well
By the PSU blowing air onto the graphics card is best.
This doesn't sound ideal at all really as most psu's intake with the fan and blow out the back (so this would fight the gpu for air), even if you flipped the fan around you'd be blowing potentially hot psu air onto your gpu. I, personally, would not recommend this setup to the OP.
The case comes with 2 x 120mm fans in the front as intake, a 120mm at the rear as exhaust and a 140mm on top as exhaust.
It seems like you have an ideal fan setup already but it would help to understand:
1) what your temps are on your cpu and gpu
2) what you do with your machine (gaming, etc)
3) are your goals silence, performance, etc.
You could always try something like positive air pressure which means most fans are intake and all point to one exhaust fan to give more of a sucking effect for the hot air to be trapped and expelled. Maybe switch your rear, or top, fan(s) to intake and throw your extra fan next to psu for gpu intake like you were thinking and watch your temps for changes.
This video from silverstone demos the positive air pressure better than I can explain in text ![]()
