new to water cooling
OK, im going to make my first water cooling loop.
will consist of cpu block, and dual 180mm rad.
i dont understand pump/res stuff.
anyone want to show me a good pump and res from frozencpu, thats pretty cheap, would perfer to not spend too much money.
all i want to know is pump and res. i got cpu block and rad under controll
EDIT:
good tubing size too, whats the norm?
To answer your last question, the most common sizes are 3/8ID and 5/8OD, along with 7/16ID 5/8OD. These are the 2 most common, although there are many tubing sizes. Personally I would go with 3/8ID and 5/8OD, reason behind it is because personally I think this is the most popular size, and as a result there are more products for this size. I was originally using 7/16ID 5/8OD but due there being much more products for the 3/8ID 5/8OD tubing I switched. Honestly though either will do you just fine, the ID of the tubing doesn't affect performance really, hope this helped.
