So I've noticed in my One M8 something weird with the pixels. In this picture you can see it between the final "l" in "Fell" and "I" in "In". It's almost as if those pixels got slightly brighter than the rest. Anyone know what this is, and/or how to fix it? I've had dead pixels before, but I'm not sure if these are stuck pixels.
post-108859-0-32797700-1419799773_thumb.
https://linustechtips.com/topic/279243-strange-pixel-issue/
Would I be able to return the phone for a replacement if I still have the warranty?
50/50
If they are very very friendly, they will replace it.
EHM, TAKE A FRIEND WITH YOU!
They love to take care of "US" when they can fish more buyers by showing how good their support is.
works 90% of the time.
https://linustechtips.com/topic/279243-strange-pixel-issue/#findComment-3789697
I might just not even bother then, it's so small and only really visible at the angles. I only ever look at my phone straight on and even then, I'll get used to it. Thanks anyway though! ^^
https://linustechtips.com/topic/279243-strange-pixel-issue/#findComment-3789751
