Would love a cooler to replace my stock cooler. After playing a round of BF3, saw my temps were 99-100c scared me quite a bit. I don't know if it's normal but it scared me. I'm looking for the best cooler. Quiet. Looks nice. And does a hella good job at cooling. Budget is around 60? Could go a bit more. Case is a 300R, processor is the 4790 and my motherboard is the z97 guard pro by MSI. Was thinking of the 212 EVO. But wanted to see if there's any better coolers.
Was gonna thing of getting the u14s noctua and exchange the fans to the industrial fans by noctua to match the colors of my case (black). but idk.
https://linustechtips.com/topic/278648-recommend-me-a-cooler/
Where are you shopping/located? Budget?
https://linustechtips.com/topic/278648-recommend-me-a-cooler/#findComment-3778195
I bought a CM hyper 212 EVO a few months ago, on sale for $35. It really keeps things chilled. My i5 4670K went from 80 to 90 at 100% load with the stock Intel cooler to temps. of 50 to 60 at load with my 212 EVO. I would definately recommend the 212 EVO.
https://linustechtips.com/topic/278648-recommend-me-a-cooler/#findComment-3784360
If you can stretch your budget to ~$99 and you have room in your case for the rad i'd recommend the H100i.
Intel i7-7770K | Asus Maximus X Hero  | EVGA GTX980 SuperClocked | 16GB Memory| Samsung 960 EVO M.2 | Corsair RM 750W | Dell 27" S2716DG main display | Dual Dell ST2320L 23" Secondary displays | Windows 10
Logitech G710+ Keyboard | Logitech G502 mouse | Kingston HyperX Cloud headset | Corsair H100i
https://linustechtips.com/topic/278648-recommend-me-a-cooler/#findComment-3784500
You won't find a better cooler for the money than the hyper 212 evo. If $-perfomance is important, get that. Otherwise, a shadow rock slim would work.
Thread comparing them http://linustechtips.com/main/topic/175255-hyper-212-evo-vs-shadow-rock-slim/
Currently the shadow rock slim is only 30 dollars on newegg: http://www.newegg.com/Product/Product.aspx?Item=9SIA68V21E0643&cm_re=be_quiet-_-9SIA68V21E0643-_-Product
In the beginning the universe was created.
This made a lot of people very angry and has been widely regarded as a bad move.
-Douglas Adams
https://linustechtips.com/topic/278648-recommend-me-a-cooler/#findComment-3785631
212 EVO is solid choice!
or
Be Quiet! Shadow Rock
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/278648-recommend-me-a-cooler/#findComment-3785725
