I'm gonna build a pc for my friend, in january.
Budget is 1050€, not more, and it should be silent; obviously not extremely silent, it should be nearly audible
So here are the specs(not using PcPartPicker because i couldn't find all the parts In the Italian site)
I5-4670K
Corsair Vengeance 16GB 1600 MHz
Asus Z87-C
Dark rock 3
R9 290 ( TRI-X OC)
1TB WD Blue
Corsair Cx600M
CoolerMaster Silencio550
Wi-fi card (don't remember the
Noctua Nf-F12 PWM
I just want to know if there is anything that you would change, and why
And i also want to know if the case( silencio550) has good enough airflow(1x800rpm intake on the front, 1x nf-f12 intake front, 1x800rpm exhaust, back)
Thanks :D
"like if you could buy two Xbox Ones, put them togheter and actually play games at 1080P! Ha! BURN"
-Linus
https://linustechtips.com/topic/278612-powerful-and-silent-build/
