Static Pressure vs. Airflow
Hey everyone.
I'm looking to swap out fans on my H440 and got a but stumped when selecting fans for the front intake, which is limited to about a centimeter of clearence.
Would static pressure or an airflow fan be best for this spot?
Thanks in advance!
4790k @ 4.6 (1.25 adaptive) // 2x GTX 970 stock clocks/voltage // Dominator Platnium 4x4 16G //Maximus Formula VII // WD Black1TB + 128GB 850 PRO // RM1000 // NZXT H440 // Razer Blackwidow Ultimate 2013 (MX Blue) // Corsair M95 + Steelseries QCK // Razer Adaro DJ // AOC I2757FH
https://linustechtips.com/topic/278605-static-pressure-vs-airflow/
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
Thanks! One thing I didn't get from the video is if it is alright to use them in a restricted intake. Is it?
Just use static pressure fans, you can't really go wrong with them. Besides the temperature difference of your components is going to be negligible between AF and SP fans.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
The noctua 2000 RPM are better then sp120 performence edition
I'd take any Noctua over them may the be the original's, industrial's, or redux's.
Redux is the same as standard NF-F12s right? Just no accessories in the box.
Edit: Nope, turns out I'm way off.
the F12 is not offered in a redux. redux are basically just older models with a new color scheme and no accessories. the old p12 should be but for pressure optimized on the P14 is available. We really eed to do a petition about that or something.
Scythe are the best fans for price/performance ratio beats both corsair and Noctua http://www.scytheus.com/product/grand-flex-pwm/ just a bit noiser and if you dont care for noise Delta are the best.As for what each does airflow is a term how much air it moves in space but that air can be reduced if it has obstacles such as hdd etc which reduced their effectivnes . While static pressure is the ability to move air in a tighter maner and able to have  a stable flow that is not reduced by HDD . To visualize better imagine a very wide cone which is airflow vs a tight cone which is the static pressure
Grant us the joy of song and dance and ever watch over us in the lonely places in which we must walk - Pray to Bastet
