How's everyones Winter Temps?
Just a thread about how much your temperatures have decreased since before Winter :)
Graphics Card: 5c Cooler on idle (29c on idle, no fans YEOOO)
Processor: 5c cooler on idle and load
https://linustechtips.com/topic/278255-hows-everyones-winter-temps/
I get 29 degrees idle now! But fans are all at 1000+rpm
"Lenghts of Snakes Match Each Silent Syllable" (PTM)
Personal Build #1 Intel i7 4790K ||Sabertooth Z97 Mark 1 || Corsair H100i || 16GB Corsair Vengeance 1600mhz || Sapphire Tri-X R9 290 || 1000W EVGA PSU || Corsair Obsidian 450D  || Death Adder 2013 K70 *MX Brown*
Client Build #1 AMD FX 6300 || ASUS m5a99x EVO R2.0 || Hyper 212 Evo || 8GB Corsair Vengeance LP 1600mhz || MSI R9 280 Direct CU II || Corsair 500W || BitFenix Neos White
Well it's 20-25 degrees Celcius at winter in Dubai over here, so....
I mean in the summer it skyrockets to around 40-50 degrees, but at least the A/C is brilliant so it stays at 20-25 indoors.
Am I the only person who doesn't really get how components can get so much cooler in the winter? :D
My build: tis be ordered
I'm at around 15c ambient, 21c CPU idle, 25c GPU idle.
I put my eGPU infront of my window, which gives me even greater temps! Playing intense games with my reference card it never gets to 75 degrees!
22C Idle With 19,5C Ambient
37C Load With Stated Ambient C
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
Nice one dude!
Anyone done some temporary Winter Overclocks?
I didn't really notice a drop yet again I am in a pretty well heated house so its normally the same temperature all year round inside only if I crack a window to do some overclocking for example last year I was able to push 1.6 volts on a amd 8350 on a h100i and get a few cinebench runs in. But other then that pretty much no change in temperature.
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
GPU's are around 70C underload and CPU won't break 45C at 4.4Ghz 1.35V
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
GGWP with that CPU temps, what cooler you got?
NH-D14, I have 3 120mm fans on my case always at 12V so it helps.
|King Of The Lost|
well, 2*c lower ambient. As long as you have decent airflow means 2 degree cooler computer.
as for me it's -10*c outside and i still have the windows open trying to get rid of some excess heat.
Maybe 5-8*c cooler than peak summer, otherwise it's pretty much the same.
CPU on load = 49*C
GPU on load = 49*C
Cpu is a 5820K @ 4ghz and GPU is a 970 OCd to 1455mhz on the core and +200mhz on the memory.
I just got this system in october so i can't say how it runs during summer, but my room was smokin' HOT when i had my 8350 @ 5.1ghz and an r9 290 @ 1300mhz core and +300mhz mem.
Samung Tab S 8.4
- 9 outside  Ambient 20 cpu on 17-22C all cores . Gpu 19C under load GPU . 53C topz CPU 54C tops
CPU: i7 4790K | Ram:Corsair Vengeance 8GB | GPU: Asus R9 270 | Cooling :Corsair H100i | Storage : Intel SSD, Seagate HDDs | PSU : Corsair VS 550 | Case: CM HAF Advanced.
Trust me, when you live somewhere like Lillehammer or Aomori or New England and winter rolls around, you can start overclocking on a stock heatsink. It gets crazy cold in the north.
I mean the one on top of your processor haha
Well I've just got a steady 23 degrees average.
I may have no winter benefits, but at least I have no summer worries.
Can someone tell me some horror stories of overheating components in the summer (if you've got any?)
I...still don't get it. OC'ing with the stock heatsink :P
I have heard you can overclock the Pentium G3258 on stock cooler to around 4.0ghz or 4.2ghz fine. But probably just bullshit :P
I'm running windows 10, so HWmonitor is being a whiny little tool with compatibility errors. Intel EXTU is showing me idling at around 23°C with an ambient room temp of about 19°C. Bear in mind that that's with the case fans at 5V, and with itunes, filesystem and four firefox tabs open. Downscaling a 1080p video to 540p in Handbrake, the highest temp I got was 51°C, and it stayed at around 47°C most of the time.
This is at 4.5GHz. My fans aren't even set to start ramping up until it gets to 65°C. Tomorrow I think I'll leave the windows open and then we can get some real temperatures going.
Its a Noctua NH-D14.
|King Of The Lost|
Given the ridiculously low power requirements on the G3258 due to it being a Haswell and the fact that it only has two cores, so not a lot of heat output compared to say, my i7, which has four HT'd cores, I'd not be surprised to see figures close to those. You can certainly get a hefty overclock out of the box.
