hi i have an cm storm quickfire tk
with blue backlight and i have metal keycaps
and the backlight isnt as bright now as with stock keycaps
so i was thinking if these would help with my backlight? http://techkeys.us/collections/accessories/products/clear-mx-switch-cover
thank you  :)
https://linustechtips.com/topic/278227-will-this-help-my-back-light/
No, that wouldn't make a difference. The issue is that your new keycaps don't let as much light through.
ok thanks  :)
i also have a blackwidow ultimate classic with stock keycaps will the clear switch covers help make it brighter?
Not sure. Swap a key to find out?
