Today my outputs started having a strong static noise in the background.
Both my headphones and speakers do it.
I tried using a splitter from the jack from the back of the mobo, but they still make static noise.
Someone help please?
Motherboard: MSI Z87 G45
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/278104-strong-static-noise/
Connect any USB devices lately or any new cabled devices to your NIC?
https://linustechtips.com/topic/278104-strong-static-noise/#findComment-3771271
Alright I found the issue, I tried unplugging all of my usb jacks and one of them (when unplugged) stopped the static.
It was my old usb splitter which i didn't use anymore.
If I plug any other devices in that usb port, it doesn't make static.
So it was the splitter's fault.
Thanks for your help!
COOLING:
https://linustechtips.com/topic/278104-strong-static-noise/#findComment-3771399
