Hello Forums!
I just bought the EVGA GTX 750TI and for those of you who don't know my specs which i'm sure are quite a lot of you I'm gonna need a new PSU. To afford the PSU I want (an OCZ ZT 550W) I'm going to need the MIR. So can I send in the MIR before the card has arrived? Do I need to print it out and send it in to EVGA or can I email it in? Will they give me actual money or proprietary EVGA Bucks that I can only spend in their store?
Thanks.
I'm not sure where to put this so. . .
https://linustechtips.com/topic/277974-how-do-mirs-work/
Fill the form, mail it, and hope you get it the refund.
https://linustechtips.com/topic/277974-how-do-mirs-work/#findComment-3769940
Hello Forums!
Thanks.
You need to cut off the UPC from the box. Then you mail that in with the listed items that are in the MIR form.
i7 4770K @ 4.5GHZ, NH-D14, Kingston HyperX Black 8GB, Asus Z87-A, Fractal Design XL R2, MSI TF IV R9 280x, BTFNX 550G
https://linustechtips.com/topic/277974-how-do-mirs-work/#findComment-3769953
So I print out the MIR cut out the UPC and then mail those in and hope I get the money? That means I need the GPU to arrive from NCIX before I can mail it yes?
https://linustechtips.com/topic/277974-how-do-mirs-work/#findComment-3769972
