Why dont you just make an os partition?
If you just want to try it, why not use a USB stick or a partition to install the OS and see if you like it?
Why don't you use a virtual machine to try Steam OS on?
You can also create 2 different partitions, set up a boot loader and install Steam OS on the second partition.
Not sure how to do partitioning and stuff but for the virtual machine I know how.
https://linustechtips.com/topic/277875-how-to-backup-everything/#findComment-3769047
