So I dotn know if it's just my pebble and its a software issue or its a known bug in the software but does this happen to anyone else's pebble? (Picture) It goes away after a while but it gets extremely annoying.
Its a known bug, the only way to fix it is to replace it.
http://help.getpebble.com/customer/portal/articles/1774495-screen-issues-
Mine is doing this too, and its irritating because I've only had my Pebble for 24 hours.
https://linustechtips.com/topic/277763-pebble-screen-going-wack/#findComment-3767927
Okay, so I have have already packed mine up so I can(hopefully) replace it, but my brothers just started doing this so I have a "guinea pig" to mess with.
Things I have tried:
  • Restarting the unit
  • Factory resetting the unit
  • disabling backlight
  • using the device without 3rd party apps
  • breaking-in the device with constantly moving the screen(this makes it worse)
Neither of the devices have been damaged physically or exposed to liquid.
https://linustechtips.com/topic/277763-pebble-screen-going-wack/#findComment-3768142
So a little bit of an update: If I tap on the screen while it is "tearing", it gets worse, but if I slam it against the table it fixes it, but only for a while. With this and my knowledge of broken display cables, I can pretty much assume that it is a hardware issue. I'm going send them an email tomorrow, so hopefully they can recognize the issue and replace both of my watches (if not then my review of the Pebble will be interesting).
https://linustechtips.com/topic/277763-pebble-screen-going-wack/#findComment-3777491
