Does overclocking cpu improve fps in AC:U?
I have i5-4690k with oc msi 970 and fps is between 48-60 with ultra settings high shadows and fxaa, but i've noticed that cpu is almost always 100% especially when dropping to 48fps so If I O/C my cpu to 4.4ghz would it help with the frames ?
Maybe a  little.
My thoughts are that if you can possibly overclock it to 4.4 GHz then why not? By the sounds of it you have a pretty powerful rig.
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
Probably. AC games have always been terribly optimized and hungry for CPU. I remember getting literally 100% more fps in ACII going from q6600 at stock speeds to 3.2Ghz. And then another 60% increase when I went from Q6600 at  3.2Ghz to i5-2500k at stock speeds. And AC: Unity is aparently a disaster so you need as much horsepower as you can get.
Potatoes? Potatoes! Potatoes.
If the game is pinning your CPU at 100%, then definitely test those temperatures before you get into gaming. Improper cooling could potentially drop clocks below what you currently have when you overclock, and you could seriously damage your CPU. Also, it's possible that your CPU is already thermal throttling as it is. Although, based on what I've seen you're already getting about the max potential out of your 970.
Main System: [Windows 10 Pro] [Core i7 5960x] [Asus Rampage V Extreme] [32GB 2400mhz G.Skill Value] [Corsair AX1200] [RXT 2080 Super] [Corsair H100i] [Thermaltake Core P3]
