Hello guys!!I have this problem...my phone went into boot loop..I had this problem a while ago but i hard reset it and it was ok but now i can`t do it because after i got my ssd i made a clean install and i did not bother to connect my phone to my pc so i do not have it in my device list and now when i connect it to my pc it fails to find it as a device it says it`s a malfunctioning device...and i can not put it into EDU mode..if you have any idea how to fix this i will be very thankfull..
P.S. Sorry for my bad english :)
CPU:AMD FX-8350 @ 4.7 Ghz CPU Cooler:Akasa Venom Medusa GPU:MSI Nvidia GTX 780 3GB OC MB:Gigabyte 990FX UD5 RAM:Corsair Vengeance 2x4gb 1600mhz PSU:CoolerMaster B700 85%+ SSD:Samsung 840 EVO 120GB(Windows) a 320GB Seagate(Storage) and a 500GB Western Digital(Storage) CASE:Fractal Desigh Define S
https://linustechtips.com/topic/277393-iphone-5-boot-loop-problem/
Hold the lock buttton and the middle button that iphone has to hard reset it and open it again
that will only work if the device is actually booted i believe. I think the OP meant he factory reset it
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
hmm i`ll try but my lock button does not want to work so i`ll have to press it hard
Nah same sh*t tries to boot again...
After i got my ssd i made a clean install and i did not bother to connect my phone to my pc so i do not have it in my device list and now when i connect it to my pc it fails to find it as a device it says it`s a malfunctioning device...and i can not put it into EDU mode..if you have any idea how to fix this i will be very thankfull..
Clean install of windows? Install your usb drivers, I'm assuming you're plugged into a usb3 port which will require drivers to work.
Nope into 2.0...usb drivers are up to date and still says that the device is not working properly and i am mad...
