I am sort of new to the PC world and was wondering if anyone could help guide me in the right direction. I want to build a mid-range gaming PC for around $600-$700 US. Here is my list of parts:
CPU: AMD FX-6300 Vishera
GPU: Gigabyte R9 290x (4GB model)
PSU: Corsair CX500M
Mobo: MSI 970 Gaming
RAM: Team Zeus 1600 8GB (2X4 GB)
Storage: WD Blue 1TB
Any help is appreciated.
https://linustechtips.com/topic/277326-my-first-pc-build/
PSU: Corsair CX500M
For gaming, you want Intel.  Even if its an i3, it will outperform an FX6 and 8.  Not to mention, an FX6/8 will bottleneck a 970.
Do you live near a Microcenter by chance?  Do you need an operating system? monitor? peripherals?  Able to reuse anything from an old build?
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/277326-my-first-pc-build/#findComment-3762825
Go for the pentium g3258 and a z97 mobo, then oc the hell outta it. (I'd suggest getting a hyper 212 evo or similar to go along with it so you can push the overclock higher)
Overall the build looks fine, though you may want to drop the GPU down a little bit and put a case in there...
https://linustechtips.com/topic/277326-my-first-pc-build/#findComment-3762849
Don't go with the 290x unless you are getting it at dirt cheap prices. Go for the 970 instead. Less power, less heat, more performance, more overclocking head room in the future.
Cheap out on the RAM, go with the cheapest DDR3 you can possibly find, won't hurt any performance at all.
Go with a G3258 and a good z97 board. More features, future proof. Once you have the money, and broadwell is launched, buy an i5.
Buy an SSD, they are super cheap. 120GB from Adata or Crucial or Silicon Power. Seriously, it will make your everyday usage so much snappier, you'll thank me later.
https://linustechtips.com/topic/277326-my-first-pc-build/#findComment-3763775
Wrong forum section?
CPU: 5820K GPU: Gigabyte G1 970 RAM: 16 GB Crucial Ballistix Mobo: EVGA m-ATX Cooler: Corsair H100i Case: Xigmatek Aquila PSU: NZXT 700W Monitors: 2 x Wasabi Mango (1440p)
Do you play Go/Baduk/Weiqi? I am AGA 4D.
"We do not shop by brand, we shop by what delivers us the best performance, features and quality for the money we're spending" - Linus (Techquickie)
https://linustechtips.com/topic/277326-my-first-pc-build/#findComment-3763853
