Hey.
I yesterday build a new pc for myself and almost everything has gone fine. When I try to turn the pc on cold, the PCI-E post led stays light up and the system doesn't post.
However, when I press the reset button, I boots up fine. Some times I have to press the reset button couple of times until the pc posts correctly.
Could this be a similar problem like you used to have with old HDDs not powering up quick enough? What could I try to fix this problem?
Intel G3258
MSI GTX 760
Asus Z97-AR
Single 8 GB stick of Kingston Fury
Super Flower Leadex Gold 650
120 GB Kingston Fury SSD and a 2,5" 300 GB Samsung HDD
Thanks.
Potatoes are good for your nostrils.
https://linustechtips.com/topic/277030-problems-with-booting/
does it do the same thing if the gfx card is removed?
are you on the latest bios?
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/277030-problems-with-booting/#findComment-3759656
I haven't tried booting without a graphics card because the CPU doesn't have iGPU.
Yes, I updated the BIOS.
weird I have had 5 g3258s and they all have intel hd graphics.
http://ark.intel.com/products/82723/Intel-Pentium-Processor-G3258-3M-Cache-3_20-GHz
https://linustechtips.com/topic/277030-problems-with-booting/#findComment-3759708
Cock. Sorry.
I will try it sooner or later.
https://linustechtips.com/topic/277030-problems-with-booting/#findComment-3759724
Cock. Sorry.
no worries its just a suggestion given your symptoms.
https://linustechtips.com/topic/277030-problems-with-booting/#findComment-3759729
Have you tried clearing the CMOS?
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/277030-problems-with-booting/#findComment-3759746
