Would this setup work well for cooling?
So i drew a little image in paint of how my case currently looks like. Blue lines are airflow. Does this work good enough, or would you change something? I cant really use anything else except those fans that are installed and mentioned in the picture. If any more questions, please ask.
http://oi60.tinypic.com/2ewmvrq.jpg
CPU i7-9700K @ 5 GHz Motherboard ASUS ROG Strix Z390-F RAM Corsair Vengeance 32 GB (4x8) 3000 MHz GPU ASUS RTX 2080 ROG Strix OC x2 SLI Case Corsair Graphite 780T Storage 256 GB Samsung 860 EVO, 6 TB Seagate Barracuda PSU Corsair HX1200i, 1200W Display(s) ASUS PG279Q (1440p 165 Hz), ASUS VG248QE (1080p 144 Hz) Cooling ASUS ROG Ryujin 360 radiator Keyboard Logitech G710+ Mouse Logitech G502 Sound Logitech G35 Operating System Windows 10
https://linustechtips.com/topic/276810-would-this-setup-work-well-for-cooling/
gpu?
Sapphire R9 290 Vapor-X
looks good maybe have the top fans be an exhaust because the dust will be insane
290? have a bottom exhaust
I probably could turn the PSU around so it takes in air from the case.
Yeah that looks like a good idea, do that and everything else looks fine.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
Having the top fans intaking is giving him positive air pressure, reducing dust.
How about the other person who said the PSU might overheat, do you think that could possibly be a problem?
It shouldn't be a problem, it will cause it to run abit warmer but not enough to overheat.
Is there any software to monitor the PSU temperature? If not (i have never heard of it), how would i know if the temperature is ok?
There is no software to monitor PSU temp. To monitor it you will have to get a temperature probe and place it onto the PSU, but this is unnecessary, unless under extreme conditions PSU's don't generally overheat before other components so don't worry about it. If you do get really worried though I'm pretty sure the only way to check temps is to buy a probe.
