If you like the Android experience, then Nexus products are great. They are always the one of the first to be updated when new versions of Android come out, due to the direct link with Google. What are you planning on doing with your Nexus 7? It is only a small form factor tablet so I'm not sure it is the best for productivity (school work etc). If that is an issue for you, I'd consider another tablet. Windows 8 tablets are probably the most productivity-tailored out there, although a larger Android/iPad tablet are good for work too. From a personal perspective, I don't think Android on tablets is quite there, so I'd look elsewhere.
You were a noob once too!
https://linustechtips.com/topic/2763-nexus-products/#findComment-36570
The nexus 7 is more userful to browse the internet or watch movies. I never wrote anything on it, it is totally intended for entertainement, win8 tablets are the polar opposite.
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/2763-nexus-products/#findComment-36589
People are annoyed with the small screen from a productivity standpoint... but there is literally nothing different between the nexus 7 and other android tablets from a productivity stand point. The samsung tablets have some add ons, but android is android. So if you can get over the screen size you will be fine. I would not buy a windows tablet at this point... I owned a zune and was burned by microsoft for the last time.
I have a 2019 macbook pro with 64gb of ram and my gaming pc has been in the closet since 2018
https://linustechtips.com/topic/2763-nexus-products/#findComment-36597
