I am working on building my first PC and I have conducted about 3 months of research in order to choose my parts. During that time I came across many sites preaching that slightly positive internal pressure is better or that slightly negative pressure is the best and I didn't really care too much until now. I have a 450D with just the two standard fans in the front and the one in the back and I am trying to mount an h100i in the top but if I mount the fans on the radiator as intakes, which is what is recommended and is what I personally want to do, leaves me with four intakes and only one exhaust which I am assuming is in no way the optimal solution. So even though this is a excruciatingly stupid and boring question could any of you out there suggest a fan configuration or solution that would give me the best airflow and internal pressure? Any and all help is appreciated.
https://linustechtips.com/topic/275955-airflowfan-configuration-help/
Use your AIO as an exhaust and make your rear exhaust an intake.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Complete newb question so sorry, by AIO do you meen the two front fans? Again first timer so sorry.
AIO stands for All in One. (cooler)
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
Your H100i.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Thank you
No problem. :)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
