USB 3.0 not working
Go to solution Solved by jnmbhj,
I found how to fix this issue.
First download the driver
then extract the drivers,
go to device manager and look for the 3 unidentified device
then right click on one of the unidentified device and select update driver software.
Then click Browse my computer for driver software. and it should end like this  "Asmedia_USB3_XPVistaWin7-8-81_VER116120\Driver"
and click next then it would stay ASMedia XHCI controller.
And do it for the other 2 unless you have more usb 3.0.
Each controller can control 2 USB 3.0 ports
My motherboard has 6 usb 3.0 ports (4 in the back and 2 in the front) Therefore I have 3 controllers.
I hope this might help other people that might have the same issue.
I am not sure why but my USB 3.0 is not working. I have tried to install the latest drivers but it appears that it cannot be installed. (it prompts me to give access but nothing pops up.) Everything else is updated to the latest.
I have tried to run it as admin but same result
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/275244-usb-30-not-working/
has it worked before if not check if the cable is plugged into the usb 3.0 pin connector on your motherboard
Yes I have tried that but I also tried connecting it to my motherboard. It still doesnt work as well. Tried it with 2 different 30 pin usb connector and tried all the ports on the back of my motherboard.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3737638
Do the 4 3.0 USB ports on your backpanel work? And if they do, the cable for the USB 3.0 ports on the front for your case is that in the proper slot for it?
Apart from that, check here for drivers for the USB controllers. http://www.asus.com/Motherboards/SABERTOOTH_990FX_R20/HelpDesk_Download/
CPU:Intel I7-6700k , CPU Cooling: Cooler Master Hyper 212 EVO MB: Asus Maximus VIII Hero, Ram: Kingston 2666 Mhz 16GB, GPU: EVGA GTX 1080 SC ACX 3.0, PSU: Corsair AXi 860W, HDD: Seagate Barracuda 1x2TB, WD Green 1TB, Seagate Barracuda 1TB, Samsung 1TB, SSD Samsung 840 120GB (OS DRIVE), SSD Samsung 840 250GB, Case: Enermax Fulmo GT.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3737754
I tried connecting it to each of the the back plate directly to the motherboard and it did not work. And yes I tried downloading the drivers from that website and it did not load.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738022
Did you fool around in the BIOS a bit and might have done something there that it might have turned the USBs off?
And for the record the 2.0 usb ports work?
Never seen this issue before.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738170
Yea I know, its something rare. Usb 2.0 works just fine and I have checked bios and there is not option to enable or disable usb 3.0.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738299
Perhaps when you installed the drivers in the first place they got corrupted. I would recommend uninstalling the from device manager, just to see if that makes a change. For instructions on how to accomplish this, check here. Tell me what happens once you do this and restart your computer
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738351
It was not corrupted before, It was kinda strange that this happened all of the sudden.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738585
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738638
Having seen quite a few strange driver issues during my time, I'd still recommend doing the steps listed above. It won't hurt the computer if done properly and has a good chance of fixing it.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738651
Grats on the fix!
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738654
Grats on the fix!
Thanks
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738672
This was one of the more difficult ones. As deleting the drivers didn't do much and when reloaded it still could not be found.
https://linustechtips.com/topic/275244-usb-30-not-working/#findComment-3738688
