My First Build
Go to solution Solved by the jolly roger,
watch out for the double post m8
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/274603-my-first-build/#findComment-3728505
Sry how does 1 like delete this post most of been my internet cuz I pressed submit 2 times
Specs: Intel i7-4790k | Corsair H60 | Asrock Z97 Pro4 | 4x4g Corsair Vengeance | Gigabyte g1 970 | Sandisk u110 128GB SSD | 1TB Toshiba Hard Drive | Corsair RM750 | Corsair Air 540 4 Corsair AF120 LED Purple 2 Corsair AF140 LED Purple
https://linustechtips.com/topic/274603-my-first-build/#findComment-3728521
A mod will do it , you can't really delete your posts.
k
https://linustechtips.com/topic/274603-my-first-build/#findComment-3728539
