Help me with A Case
Go to solution Solved by Clyne,
Dont like green and small. :)
I stumbled upon this do you think this will work?
http://www.nzxt.com/product/detail/111-switch-810-case.html
Should be fine to power your X99 build or 8350 build.
Hello,
I have been using my system (specs in signature) for 2 years. It started with a stock cooler, one ram stick 1 HDD and a small PSU, stock fans. I didnt know how to OC so I didnt care. Now I have an H100i 2 rams sticks, 1 HDD and 1 SSD and an AX1200i. I also have lots of Noctuas now.
My problem, the Cooler Master HAF XM mid tower is small for my future X99 EATX System and further cooling upgrades.
My question, can you guys suggest me a good case which has future custom loop potential but is under 250. Windowed would be nice and full tower. Probably more fans can be put then my current case.
I was gonna get the corsair 780t but it does not have potential for a lot of fans.
Remember under $250 USD.
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/274393-help-me-with-a-case/
get two 450Ds and make a 900D! :D
But really C70 or a Fractal Design XL R2
https://linustechtips.com/topic/274393-help-me-with-a-case/#findComment-3726273
Should work fine.
https://linustechtips.com/topic/274393-help-me-with-a-case/#findComment-3726289
