What are the uses, budget, location, and do you need windows or peripherals? AND are you interested in potentially upgrading your build in the future? I might be able to squeeze out a better build, or I might not be able to. :D
Mostly gaming and some casual browsing. Budget is around €400 ($500ish) and the location is Ireland. I don't need any peripherals or an OS. I probably will try to upgrade, but it will be a while before that happens so it's not a major concern.
(I believe) this is the same build (for convenience): http://pcpartpicker.com/p/Lz9rP6
https://linustechtips.com/topic/274228-1st-build-thoughts/#findComment-3724402
