Hi, I was wondering if I should get a new case, i have a corsair 350d with a I5 4670k OC 4.7gb, 8gb 1600mhz OC to 2000mhz memory, gtx 980, on an ASUS gene z87 motherboard, a new Samsung 4k monitor, and corsair TX650m I'm planning on getting another gtx 980 with a new PSU 850 or 1000 and I'm also going to water cooling gaming pc, I'm scared of the corsair 350d top mounted 240mm radiator if its 30mm thick surported the front mounted not so much, what should i do? should i keep my case or what for the ARC mini R2 when it comes into stock since that case and surport two radiators a triple on top and dual in the fornt.
https://linustechtips.com/topic/273696-case-and-a-psu/
