FrozenQ res leaking.
Solved by Ghost,
You're lucky. I had this issue on a graphics card water block once. Ended as bad as you'd expect. :(
What you need is a spacer: http://www.specialtech.co.uk/spshop/customer/Bitspower-4mm-Spacer-Ring-for-14-Thread-Shiny-Silver--BP-WTP-C25-pid-15197.html
It should be supplied with the probe for these circumstances but obviously wasn't.
1
5
1
toxic_worper ·
8
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
