Hi,
I was looking into a building a custom case, and was looking for a company that pre-builds a power switch that I can just plug into my motherboard and then install on the front of the case. Is there such thing? I am not great with electronics and don't really want to be building my own switch.
https://linustechtips.com/topic/273327-power-switch-on-custom-case/
Hi,
Pretty much any non-latching switch in existence will work for you. Most people use anti-vandal switches though.
look at the vandal resistant switches on frozen cpu, im sure that they will match your colour scheme
So if I bought this:  http://www.frozencpu.com/products/8697/ele-373/White_Illuminated_Vandal_Resistant_Latching_Switch_-_22mm_-_Black_Housing_-_Ring_Illumination.html?tl=g52c341
And then bought this:  http://www.frozencpu.com/products/8096/ele-352/ModSmart_EZ_Vandal_Switch_Cable_-_Universal.html?tl=g52c341
Would this all work? How would I wire the switch?
Thanks for all of your help
