Just wanting some opinions on software I've chosen to keep my PC safe and speedy.
Security:
- Malware Bytes
- Kaspersky
Speed
- CCLeaner
Suggestions?
Looking for a Programming Project take a look here!
http://linustechtips.com/main/topic/407332-looking-for-a-project-idea-start-here/
https://linustechtips.com/topic/273302-pc-security-speed/
Security:
- Malware Bytes
- Kaspersky
Speed
- CCLeaner
Suggestions?
Two antiviruses at the same time?
Eugh. I'm not sure how beneficial that could be as stuff could be going through 2 checking software things.
Sig under construction.
https://linustechtips.com/topic/273302-pc-security-speed/#findComment-3711019
Meant to put a "or" was not sure which choose. On phone sorry
https://linustechtips.com/topic/273302-pc-security-speed/#findComment-3711071
Malwarebytes Pro is all the security any end user should need. Tie that in with a few browser extensions (like Disconnect) and common sense.
I have plenty of common sense, Havnt really used a antivirus before.
https://linustechtips.com/topic/273302-pc-security-speed/#findComment-3713282
Security:
- Malware Bytes
- Kaspersky
Speed
- CCLeaner
Suggestions?
I would also get ZoneAlarm Firewall  and get rid of kaspersky its horrible........get avast much better and plus you get internet protection as well.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/273302-pc-security-speed/#findComment-3713552
Actually any anti-virus should do the job fine. So what you have is quite nice. If you don't mind a little bit of harassment from software, look at comodo Firewall. It will annoy you a little but basically prompt you to allow or deny application access to the Internet. I find it useful because I play with interesting software, so I want to know what is trying to get on the net without my permission.
https://linustechtips.com/topic/273302-pc-security-speed/#findComment-3725585
