Hi guys, i was wondering whether it would be possible to use an hdmi on my gpu as an inlut for my ps3. The monitor has a free hdmi input but it would meen more cables to run under there. If it is any help the gou is a dc2 gtx 770
Thanks in advanced
No. You will have to plug in monitor.
Thanks in advanced
Will not work. Sadly, it only outputs, and will not input. As the others have said, you'll need to plug it into the TV. Get an XBONE and you can plug the PC into the XBONE and plug the XBONE into the tv  :P
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
