Hello LTT Members, need a bit of help here if you don't mind.
My ISP just released an addon to my plan for "unmetered" bandwidth and I thought it be great to take advantage of this and restart my youtube channel. Issue is, when I attempt to render out it takes HOURS, and I mean HOURS to render out a 5 minute video (specs down below).
Specifications:
AMD FX-8350
16GB DDR3
2x HD7870's (Gigabyte OC)
AX1200i
120GB Samsung Evo
6x 500GB WD Velcios.
Rendering Software:
Cinema4D R15/R16 (some options aren't in R16)
Adobe Premier Pro / After Effects
Sony Vegas
Now I need a rendering rig, 2 of my options is this ..
I can buy a SuperMicro and a AMD Opteron 6272 (16 Core CPU (I'll get two of them)), memory (32GB RDIMM ECC), and 2 Noctua G34 120mm coolers. for $1,104.38
- This one will use my same parts to help? Will this help me with better rendering.
The second options is upgrading the whole rig. Can someone price out a $2,500 PC rendering rig. Intel/AMD doesn't matter. (Including CAD Prices and Alberta Taxes (5%)). It'd be great!
Thanks.
https://linustechtips.com/topic/272916-i-need-help/
It should not be taking hours to sender out a 5minute video on that hardware make sure your rendering with your gpu's
Also just letting you know that memory express beats prices by 10%
https://linustechtips.com/topic/272916-i-need-help/#findComment-3702478
Wait wait what the heck. Don't render vids, I used to edit 1080p videos 30mins at less then 20 minutes with same processor but lot weaker gpu and ram.
Plus don't invest In the channel like this, it's a 1/1000 oppurtiountiy.
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/272916-i-need-help/#findComment-3702493
Favorite place to shop. And Cinema4D is using CPU To render out and its taking ages to do a render.
https://linustechtips.com/topic/272916-i-need-help/#findComment-3702497
It won't just be for the channel as I do, do graphics design and 3D modeling as well.
https://linustechtips.com/topic/272916-i-need-help/#findComment-3702512
you need a plugin like fdurryball to render with the gpu def worth it
https://linustechtips.com/topic/272916-i-need-help/#findComment-3702533
Here ya go it should do all the editing and rendering you would ever need and is well below your budget with plenty of room for upgrades. If you feel like you want to re-use any part of your current pc just take that part off of this one. You could even add a second 970 if you felt like it.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($429.89 @ DirectCanada)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($109.99 @ Canada Computers)
Motherboard: MSI X99S SLI Plus ATX LGA2011-3 Motherboard  ($249.98 @ DirectCanada)
Memory: Crucial Ballistix Sport 16GB (4 x 4GB) DDR4-2400 Memory  ($264.98 @ Newegg Canada)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($139.89 @ DirectCanada)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($109.98 @ DirectCanada)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($397.69 @ DirectCanada)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($104.98 @ Newegg Canada)
Total: $1923.43
Generated by PCPartPicker 2014-12-19 00:51 EST-0500
https://linustechtips.com/topic/272916-i-need-help/#findComment-3702547
Case: Fractal Design Define R4 w/Window (Titanium Grey) ATX Mid Tower Case ($116.05 @ Vuugo)
Total: $1923.43
That other build he mentioned would be better I think, especially if he throws his GPU's into that build.
https://linustechtips.com/topic/272916-i-need-help/#findComment-3702837
You might hold off on the GTX 980 and see what kind of performance you get with the HD 7870s in the new system.
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($119.99 @ Memory Express)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard  ($298.85 @ Vuugo)
Memory: G.Skill Ripjaws Series 32GB (4 x 8GB) DDR4-2133 Memory  ($542.48 @ Newegg Canada)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Western Digital WD VelociRaptor 500GB 2.5" 10000RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: EVGA GeForce GTX 980 4GB ACX 2.0 Video Card  ($646.98 @ Newegg Canada)
Case: Fractal Design Arc Midi R2 ATX Mid Tower Case  ($109.99 @ Memory Express)
Power Supply: Corsair 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply  (Purchased For $0.00)
Total: $2148.18
Generated by PCPartPicker 2014-12-19 04:19 EST-0500
https://linustechtips.com/topic/272916-i-need-help/#findComment-3703562
