im trying to build my first pc because my laptops live is slowly nearing its end.
my budget is not high and is not helped by the fact that i live in the netherlands.
I have the goal of keeping the total price below €700 eu > 860 usd (due to insane pricing over here this comes down to 700usd
with help from here i managed to make a list of components i belive will work .
I would like to ask you guys if i have made any mistakes in my choices, i was also wondering what performance i might expect in games like far cry 4.
my choices for parts are based on what i could easely obtain here
a list of the parts in pc partpicker(with out a case)
http://pcpartpicker.com/p/pzwVZL
same list with the case from a dutch site
http://goo.gl/z6Z2Cm
any help is highly appreciated
https://linustechtips.com/topic/272619-first-ever-buildhelp/
Looks good, You will be able to handle almost everything at pretty good graphics.
Personally i would not go with Asrock, But they are a rebranded branch from Asus so it doesnt really matter.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/272619-first-ever-buildhelp/#findComment-3698596
WD Green drives are not suitable system drives. Get a Seagate Barracuda or WD Blue instead. If neither of those are available you could go with a Toshiba although it has a smaller cache and will not perform quite as well.
https://linustechtips.com/topic/272619-first-ever-buildhelp/#findComment-3698659
thank you
was not aware of this may i ask why those drives are suitable and a green is not
https://linustechtips.com/topic/272619-first-ever-buildhelp/#findComment-3698682
thank you
The Blue and Barracuda are 7200 rpm drives designed for reasonably high read/write traffic. WD Green are 5400 rpm drives (slower access) designed principally for archival storage. They are not built to take the frequent reads & writes of a system drive.
https://linustechtips.com/topic/272619-first-ever-buildhelp/#findComment-3698845
