Help with SLI/ surround
Go to solution Solved by Lays,
I plugged in 2 monitors into the bottom gpu, and started my computer back up, then it worked.
I just installed my second 780, and now my comp doesn't want to go into Surround:
Before it was working fine, I put the second card in, replugged everything in, checked all the cables, etc.
ALL 3 MONITORS ARE WORKING NORMALLY, JUST NO SURROUND
https://linustechtips.com/topic/27245-help-with-sli-surround/
NEVERMIND I FIXED IT
https://linustechtips.com/topic/27245-help-with-sli-surround/#findComment-346201
Haha great to see you solved it, mark the post as solved so you people will not come to help! I also have asus monitors in surround!
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/27245-help-with-sli-surround/#findComment-346235
Post your solution and mark it as solved. People having issues with SLI or Surround may have the same issue as you.
https://linustechtips.com/topic/27245-help-with-sli-surround/#findComment-346240
how I do dat
ignore that i read the pinned topic
https://linustechtips.com/topic/27245-help-with-sli-surround/#findComment-346294
https://linustechtips.com/topic/27245-help-with-sli-surround/#findComment-346299
