I just  finished building the pc. when i hitted the power button nothing happened so i cheked every wire and fixed some tried again nothing happened. so tested is the psu dead with paperclip system and it was fain. now tried to pull one cable a time and tried to boot and i found a the problem when cpu gets power the pc wont boot but when doesnt all fans and optical drive are in function and some other compents. and when i boot i cant shut it down via power button i must close it via psu button.
here is my part list i teaked this build http://austinnotduncan.com/builds/photon/
AMD Athlon X4 760K MSI A78M-E35
 sapphire r9 270x dual x
8GB Crucial Ballistix Sport
1TB Western Digital Black
corsair cx 600
case corsair spec 01
If you want affordable games on G2A click here https://www.g2a.com/r/pyyzi
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/
then mabe your cpu is dead
Gaming rig) i5-4690k@3,5ghz,4,1ghz turbo , gigabyte z97x-gaming 3, hyperx fury red 2x4gb(1600mhz), msi GTX 970 gaming 4, corsair cs650m PSU, corsair carbide spec-03 case, be quiet pure rock Cpu cooler, kingston v300 120gb ssd, samsung evo 830 120gb ssd, segate baracuda 1,5tb hdd, Laptop 1) HP pavilion power, i7 7700hq, 16gb ddr4, 256gb nvme ssd, 1tb hdd, nvdia gtx 1050 Laptop 2(linux mint)Dell Xps 15(2011), i3-2130m, nvidia gt525m, 4gb 1333mhz ram, 500gb hdd Laptop3(mint and windows)Dell inspiron 15z(2013), i5-3337u, hd 4000 graphics, 6gb 1600mhz ddr3, 500gb hdd, 32gb ssd(RST) First PC(still using for some windows XP programs)Amd athlon xp 1500+@1,96ghz, 2gb 300mhz ram, PNY geforce 6200, 80gb maxtor hdd, asus(tek) a7n8x-deluxe , 450W psu, spire case
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/#findComment-3695553
Did you put thermal paste on the cpu?  Did you also hook up the cpu fan?
yes i did. i think  the mobo has something wrong beacause only fans and optical drives gets power.
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/#findComment-3695632
pyyzi did you not say your pc boots up?  So does it make it into Windows or not?
Also it sounded like your problem mentioned at the end of your post was just getting it to power on with the power button on the case and the video I provided above in my previous post shows you an example of how to do this.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/#findComment-3695664
no only fans start spinning and opticaldrive works
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/#findComment-3695692
are the fans plugged in to the mobo or PSU and maybe your keyboard or mouse etc are bugging. try unplugging all external/internal usb, only connect a monitor and a p/s2 keyboard try again,
did you plug the 8 pin cpu in the right connector on psu(if you have a modular psu)
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/#findComment-3696241
fans are plugget in mobo. and nothing happend when i tooked all usb.
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/#findComment-3706325
hmm strange then i cant help you ennymore
https://linustechtips.com/topic/272384-my-first-pc-boot-problem/#findComment-3708800
