Hey guys
I had problems with an a8 so I downgraded back to my a4 also back to my old heatsink.
Suddenly after that, everything is fine and normal and then suddenly my fan sounded like a jet. My usage on it was 70% and above and then the fan sounded like a jet at 65C to 74C max with 70% usage.
It did not do this before. Did BIOS change the fan settings or what?
https://linustechtips.com/topic/272279-cpu-temperature/
If it didn't happen before it is not normal.
Reseat the heatsink with new thermal paste and make sure to clean both the cpu and the heatsink.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/272279-cpu-temperature/#findComment-3694759
yes as mentiond above you should check the termalpaste
Gaming rig) i5-4690k@3,5ghz,4,1ghz turbo , gigabyte z97x-gaming 3, hyperx fury red 2x4gb(1600mhz), msi GTX 970 gaming 4, corsair cs650m PSU, corsair carbide spec-03 case, be quiet pure rock Cpu cooler, kingston v300 120gb ssd, samsung evo 830 120gb ssd, segate baracuda 1,5tb hdd, Laptop 1) HP pavilion power, i7 7700hq, 16gb ddr4, 256gb nvme ssd, 1tb hdd, nvdia gtx 1050 Laptop 2(linux mint)Dell Xps 15(2011), i3-2130m, nvidia gt525m, 4gb 1333mhz ram, 500gb hdd Laptop3(mint and windows)Dell inspiron 15z(2013), i5-3337u, hd 4000 graphics, 6gb 1600mhz ddr3, 500gb hdd, 32gb ssd(RST) First PC(still using for some windows XP programs)Amd athlon xp 1500+@1,96ghz, 2gb 300mhz ram, PNY geforce 6200, 80gb maxtor hdd, asus(tek) a7n8x-deluxe , 450W psu, spire case
https://linustechtips.com/topic/272279-cpu-temperature/#findComment-3695570
