$3000 build NEED HELP!
Solved by nishank93,
Congratulations on typing all that with an XBox controller!
Get more RAM (no reason why, a 2*8GB kit will serve you well), Get an AX860i instead of the AX1200 (You don't need 1200W). Get the 840 Pro (Faster). Get Windows 8 (Faster).
EDIT: I agree with some posts here. Get a 780 first, and add another later if you think it is holding you back.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
7
michaelb198 ·
Posted in Peripherals2
