I have two pieces of cable sleeving picked out. It doesnt say if its paracord or not but i think it is. If the price is two high or there is a better cable sleeving out there i would love your recommendations. I have no idea what tools to buy as this is my first sleeving project. Also do i need heatshink if even a little i need a lot of help if you could just go over all the basics.
http://www.frozencpu.com/products/13929/slv-205/Bitspower_Super_Tight_Weave_116_Cable_Sleeve_Deluxe_-_White.html?tl=g35c535s1521
http://www.frozencpu.com/products/13930/slv-206/Bitspower_Super_Tight_Weave_116_Cable_Sleeve_Deluxe_-_Blue.html?tl=g35c535s1521
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/27219-need-help-with-cable-sleeving/
First thing i would do is do your research. the product you selected is a plastic not paracord.  Watch lutro0's videos i would also use the heatsrinkless method because it is the cleanest and best looking method.
i buy my cord from lutro0 it is the best quality for the best price.
i would also worn you if you are using white sleeving i would use white wire it looks better becasue black or muti colored wires will show through
watch this video....
and this is the product
http://lutro0-customs.com/products/lc-stiff-line-sleeving-light-blue-25ft
http://lutro0-customs.com/products/lc-stiff-line-sleeving-white-25ft
make sure to make best answer if this answers your questions
If you're thinking of using paracord, there are many cheap paracords that sell in large quantity on eBay and a variety of colours. (Look for 550 paracord).
I sleeved my cables with these sleeves and it looks great and is very easy. You can also use the heatshrink-less method with paracord for a nice clean look.
Also buying the set of the pin removers for the connectors will save your life and you will need lighters.
CPU: Intel 2700k (4.7) MOBO: Asus P8Z77-V DELUXE GPU: Sapphire Vapor-X R9 290X RAM: 16GB Corsair Vengence (1866) CPU Cooler: Corsair H100i w/ 2x Noctua NF-F12 Storage: 256GB Samsung 830 Pro SSD (Boot), 64GB Crucial M4 (SSD Cache), 1TB WD Black Cavier, 2TB Hitachi, 2.5TB Buffalo Sound Card: Xonar Essence STX Case: Corsair Graphite 600t w/ full acrylic side PSU: Corsair HX750 (individually sleeved)
Peripherals: Filco Keyboard (Brown) Razer Deathadder, Sennheiser HD595, Zalman ZM-MIC1, Steelseries Qck Mass mousepad.
Pics of my Rig
