I want to play DayZ SA at a higher rendering resolution but every time i put it over 100% this happens
http://cloud-4.steampowered.com/ugc/535131928198717655/280A520B255F073B18481D707FCE557943FF3D8C/
It has not always done this and i want to know if this is a DayZ problem or just my bad luck. I have tried re-installing etc.
https://linustechtips.com/topic/272078-dayz-sa-rendering-problem/
a bug, as expected. i mean come on early access, why did you purchase it
It is still a good game, i have 800hrs played i just wanted to know if this was just a problem i am having as it has never done this before.
Works with my 7970. Have you tried different drivers? My friend also has tried it with his 970/latest driver and it works also. Hopefully someone can help you.
Thanks i will have to roll back my drivers and check it out.
like this for exemple.
Yes i am aware of those, it is just the GPU usage that is bad.. In forests 80% and in towns 25-40% putting up the rendering resolution increases the GPU usage but keeps the frames near enough the same. With a higher rendering resolution it also makes Antialiasing less important and you can lower or disable it.
lemme find that bf4 performance tweak video once i get home, it changes something in the nvidia gpu usage. cant remember now, but it should help in any game. brb.
may your framerates be high and your temperatures be low. #pcmr
