HI everyone, having some no post issues.
So I have built a PC, then set it up, the power button did not work, so i checked where i had it plugged in and changed it, now that works fine. but i get no display when i try to boot, so i changed the display from the gpu to the mobo gfx with both VGA and DVI and still nothing, then I double checked the CPU to make sure it was seated properly, it was. so I reset the bios (cmos) whatever it is, and made sure the mobo battery still had power, it did. But still no display. I can tell you that the PSU and mobo are both working as all fane are spinning like a tassie devil on its rags, same with the GPU fans. I also re seated the RAM with both sticks in the zero slot once at a time, and then into slot one, still nothing. the only thing I can think of is a grounding issue, so tomorrow i will take the mobo back out and re ground it, then re assemble. but before I do that does anyone have any tips?
https://linustechtips.com/topic/271901-troubleshooting-no-post/
Check the monitor on another system.
If it works: Remove the gpu from new system. Using same cable as tested on other system run off the iGPU.
I know the monitor works, as its my second monitor from my main system, but yes I have tried removing the GPU and using the onboard, still nothing.
https://linustechtips.com/topic/271901-troubleshooting-no-post/#findComment-3692309
