So my Intel fan random spazzed out due to a brownout. The psu failed to knock its self out. Anyways the rpm is going crazy. The actual temps are fine but the rpm is going up and down up and down. Its weird. Ive pumped up my gpu fan because that is loud and i didnt like the weird fan.
Listen if you care.
https://linustechtips.com/topic/27145-blade-ripped-off-intel-cooler/
I would just get another box cooler or buy an aftermarket cooler.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
Well its a HTPC so ill just buy the cheapest fan that seems ok. Any decent fans for under £10. Btw for people that are worried it was a 300w be quiet psu.
Listen if you care.
 Just get another box cooler from www.scean.co.uk That is where I get most of mky pc stuff from. Except I use a H100i not a box cooler because it is a gaming rig not a htpc.
I just took the old heatsink from an e8800 machine. I used vodka because i dont have the fancy stuff. It works, vodka forever, it tastes bad however.
Listen if you care.
Listen if you care.
What are you going on about vodka for. Are you using that to remove the thermal interface material.
Yes, it fine, i used glasses cleaners(new one) to wipe it off. Ghettod the hell out of it. Anyways it works fine. Its not the computer that im typing this on but whatever. Arctic silver of course
Listen if you care.
I personally like to keep things by the book. I use the ArctiClean kit and my Thermal Compound of Choice is Arctic Cooling MX-4 Only problem with it is that sometimes it acts like glue which is no good. I managed rip a cpu out of a socket by trying top remove a heatsink that had that stuff on. It was hell. I also bent 6 of the pins on that cpu but I fixed it and now the cpu works fine :)  .
